Ana içeriğe geç
RYDIS H68 Pro Wheel Replacement
Neye ihtiyacın var
  1. RYDIS H68 Pro Wheel  Replacement, Battery: adım 1, 2 resimden 1. RYDIS H68 Pro Wheel  Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
  2. RYDIS H68 Pro Wheel  Replacement: adım 2, 1 resimden 1.
    • Lift the battery cover up to reveal the battery.
    • Remove the battery.
  3. RYDIS H68 Pro Wheel  Replacement, Bumper: adım 3, 3 resimden 1. RYDIS H68 Pro Wheel  Replacement, Bumper: adım 3, 3 resimden 2. RYDIS H68 Pro Wheel  Replacement, Bumper: adım 3, 3 resimden 3.
    • Remove the eight 10 mm Phillips #1 screws.
  4. RYDIS H68 Pro Wheel  Replacement: adım 4, 3 resimden 1. RYDIS H68 Pro Wheel  Replacement: adım 4, 3 resimden 2. RYDIS H68 Pro Wheel  Replacement: adım 4, 3 resimden 3.
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. RYDIS H68 Pro Wheel  Replacement: adım 5, 3 resimden 1. RYDIS H68 Pro Wheel  Replacement: adım 5, 3 resimden 2. RYDIS H68 Pro Wheel  Replacement: adım 5, 3 resimden 3.
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. RYDIS H68 Pro Wheel  Replacement, Wheel assembly: adım 6, 1 resimden 1.
    • Remove three 10mm Philips #1 screws that are securing the wheel assembly.
  7. RYDIS H68 Pro Wheel  Replacement: adım 7, 2 resimden 1. RYDIS H68 Pro Wheel  Replacement: adım 7, 2 resimden 2.
    • Remove the 10mm Phillips #1 screw securing the spring.
    • Then undo the spring from the plastic hook to completely remove it from the wheel assembly.
  8. RYDIS H68 Pro Wheel  Replacement: adım 8, 3 resimden 1. RYDIS H68 Pro Wheel  Replacement: adım 8, 3 resimden 2. RYDIS H68 Pro Wheel  Replacement: adım 8, 3 resimden 3.
    • Lift up on the plastic piece to remove the entire wheel assembly.
  9. RYDIS H68 Pro Wheel  Replacement: adım 9, 3 resimden 1. RYDIS H68 Pro Wheel  Replacement: adım 9, 3 resimden 2. RYDIS H68 Pro Wheel  Replacement: adım 9, 3 resimden 3.
    • Remove the plastic frame by pulling outward on the two spots where it is fastened.
  10. RYDIS H68 Pro Wheel  Replacement: adım 10, 2 resimden 1. RYDIS H68 Pro Wheel  Replacement: adım 10, 2 resimden 2.
    • Remove the four 10mm Phillips #1 screws around the edges of the cover.
  11. RYDIS H68 Pro Wheel  Replacement: adım 11, 3 resimden 1. RYDIS H68 Pro Wheel  Replacement: adım 11, 3 resimden 2. RYDIS H68 Pro Wheel  Replacement: adım 11, 3 resimden 3.
    • Lift up on the top cover to remove it.
    • Removing the top cover reveals the gear system consisting of three gears.
Sonuç
Shawn O'Meara
101 İtibar
1 Kılavuz yazıldı
Ekip
USFT-Lacy-S17S005G2 USFT-Lacy-S17S005G2 üyesi
Local Repair Groups
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 38
Her zaman: 590
