Ana içeriğe geç
RYOBI P422 Body Replacement
Neye ihtiyacın var
  1. RYOBI P422 Body Replacement, Battery and Handle: adım 1, 2 resimden 1. RYOBI P422 Body Replacement, Battery and Handle: adım 1, 2 resimden 2.
    • To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
    • To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
  2. RYOBI P422 Body Replacement, Body: adım 2, 1 resimden 1.
    • Lay the grinder flat on its side so the screws are facing up.
  3. RYOBI P422 Body Replacement: adım 3, 3 resimden 1. RYOBI P422 Body Replacement: adım 3, 3 resimden 2. RYOBI P422 Body Replacement: adım 3, 3 resimden 3.
    • Remove the four 1.8 cm screws from the lower and mid section of the body with the Torx T20 screwdriver.
    • Remove the 3.7 cm screws from the upper section of the body, with the same screwdriver.
  4. RYOBI P422 Body Replacement: adım 4, 2 resimden 1. RYOBI P422 Body Replacement: adım 4, 2 resimden 2.
    • Now that the two halves are unscrewed, lift up the top half.
  5. RYOBI P422 Body Replacement: adım 5, 3 resimden 1. RYOBI P422 Body Replacement: adım 5, 3 resimden 2. RYOBI P422 Body Replacement: adım 5, 3 resimden 3.
    • Remove the safety trigger and the spring.
    • Be careful in removing the safety trigger, the pin may fall out as you are moving it.
  6. RYOBI P422 Body Replacement: adım 6, 2 resimden 1. RYOBI P422 Body Replacement: adım 6, 2 resimden 2.
    • Lift up main trigger and spring together.
    • By lifting this trigger and spring out of the handle, you will pull double duty by lifting the black switch box off of its two support posts.
    • Slide the trigger off of the black switch box.
    • Be careful when removing trigger, the spring will be compressed and may move unexpectedly.
  7. RYOBI P422 Body Replacement: adım 7, 3 resimden 1. RYOBI P422 Body Replacement: adım 7, 3 resimden 2. RYOBI P422 Body Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Lift the battery lead bracket from its slot.
    • Use the PH 1 screwdriver to unscrew the two 0.7 cm screws that hold the 2.6 cm long brass bracket in place.
    • Use tweezers to remove the brass bracket.
    • During reassembly, remember to keep the spring inside the main trigger and against the bracket that is visible in the second of the accompanying photos.
  8. RYOBI P422 Body Replacement: adım 8, 2 resimden 1. RYOBI P422 Body Replacement: adım 8, 2 resimden 2.
    • Flip the grinder over and lift off the second half of the body.
    • Now you can replace your damaged handles with a new pair.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
John Lamanuzzi
229 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-6, Duarte Spring 2015 UMass Dartmouth, Team 3-6, Duarte Spring 2015 üyesi
UMASSD-DUARTE-S15S3G6
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 1,494
