Ana içeriğe geç
RYOBI P422 Safety Trigger Spring Replacement
Neye ihtiyacın var
  1. RYOBI P422 Safety Trigger Spring Replacement, Battery and Handle: adım 1, 2 resimden 1. RYOBI P422 Safety Trigger Spring Replacement, Battery and Handle: adım 1, 2 resimden 2.
    • To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
    • To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
  2. RYOBI P422 Safety Trigger Spring Replacement, Safety Trigger Spring: adım 2, 1 resimden 1.
    • Lay grinder flat on its side so the screws are facing up
  3. RYOBI P422 Safety Trigger Spring Replacement: adım 3, 3 resimden 1. RYOBI P422 Safety Trigger Spring Replacement: adım 3, 3 resimden 2. RYOBI P422 Safety Trigger Spring Replacement: adım 3, 3 resimden 3.
    • Remove the four 1.8 cm screws from the lower and midsection of the body with a T20-20 Torque screwdriver.
    • Remove the 3.7 cm screws from the upper section of the body, with the same screwdriver
  4. RYOBI P422 Safety Trigger Spring Replacement: adım 4, 3 resimden 1. RYOBI P422 Safety Trigger Spring Replacement: adım 4, 3 resimden 2. RYOBI P422 Safety Trigger Spring Replacement: adım 4, 3 resimden 3.
    • Now that the two halves are unscrewed, remove the top half
  5. RYOBI P422 Safety Trigger Spring Replacement: adım 5, 3 resimden 1. RYOBI P422 Safety Trigger Spring Replacement: adım 5, 3 resimden 2. RYOBI P422 Safety Trigger Spring Replacement: adım 5, 3 resimden 3.
    • Remove the safety trigger along with the spring.
    • To remove the spring, pull it gently off the bottom of the trigger.
    • When putting a new spring in make sure it slides into the grove on the bottom of the trigger.
Sonuç
Thomas Napert
249 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-6, Duarte Spring 2015 UMass Dartmouth, Team 3-6, Duarte Spring 2015 üyesi
UMASSD-DUARTE-S15S3G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 1,438
