Giriş
This guide demonstrates replacing a GPU fan in a RADEON RX580 graphics card. If you begin to notice one of the fans have stopped functioning completely, then this is an essential repair to complete. Get ready to use a small amount of physical force for some parts of this guide.
Aletler
Parçalar
Lay down the case so that the power button is on the far top right corner and is facing your right.
Remove the top panel by pushing its ridgeline away from you and sliding it off of the case.
Remove the side panel facing you by pushing its ridgeline away from you and lifting it off of the case.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
This tutorial is not complete, some extra steps are required to unplug the fans power connector.
Indeed, it’s necessary to remove the plastic support above the heat sink (where fans are screwed on) to be able to unplug the fans power connector.
First, the fan support should be removed and the connector should be unplugged before unscrewing the fans from the plastic support.
