Ana içeriğe geç
Giriş
This guide demonstrates replacing a GPU fan in a RADEON RX580 graphics card. If you begin to notice one of the fans have stopped functioning completely, then this is an essential repair to complete. Get ready to use a small amount of physical force for some parts of this guide.
Parçalar
  1. Radeon RX 580 Video Card Fan Replacement, Graphic card fans: step 1, image 1 of 3 Radeon RX 580 Video Card Fan Replacement, Graphic card fans: step 1, image 2 of 3 Radeon RX 580 Video Card Fan Replacement, Graphic card fans: step 1, image 3 of 3
    • Lay down the case so that the power button is on the far top right corner and is facing your right.
    • Remove the top panel by pushing its ridgeline away from you and sliding it off of the case.
    • Remove the side panel facing you by pushing its ridgeline away from you and lifting it off of the case.
  2. Radeon RX 580 Video Card Fan Replacement: step 2, image 1 of 2 Radeon RX 580 Video Card Fan Replacement: step 2, image 2 of 2
    • To disconnect the GPU cable, use your thumb and index finger to unlatch the hooking device and pull the cable away.
  3. Radeon RX 580 Video Card Fan Replacement: step 3, image 1 of 2 Radeon RX 580 Video Card Fan Replacement: step 3, image 2 of 2
    • Gently and carefully press down on the release mechanism on the PCIE slot of the graphics card.
    • You should hear a click which will indicate proper release from the motherboard (in this case a Tomahawk B450).
    • Do not touch the motherboard with your hands or any other device. It may result in a short.
  4. Radeon RX 580 Video Card Fan Replacement: step 4, image 1 of 3 Radeon RX 580 Video Card Fan Replacement: step 4, image 2 of 3 Radeon RX 580 Video Card Fan Replacement: step 4, image 3 of 3
    • Remove the graphics card from the motherboard by applying back pressure to the card.
    • Use both hands in this process as the card can be quite heavy.
    • Be sure to set the graphics card on a non-static surface, such as a wooden table.
  5. Radeon RX 580 Video Card Fan Replacement: step 5, image 1 of 2 Radeon RX 580 Video Card Fan Replacement: step 5, image 2 of 2
    • Remove the six 1.8 mm screws holding both fans in place by using a Phillips #1 screwdriver in-between the fan blades as the screws are located behind the fans.
    • Try not to touch the heat sink with your screwdriver as it may cause substantial damage to the system.
  6. Radeon RX 580 Video Card Fan Replacement: step 6, image 1 of 2 Radeon RX 580 Video Card Fan Replacement: step 6, image 2 of 2
    • Remove the fans by applying back pressure.
    • Unplug the individual fans from the graphics card.
Sonuç
Bir başkası bu kılavuzu tamamladı.
2 Yorum
this will not work this way unless you cut and slice wires because the fan connection is under the heatsink. this card needs the be completely opened and thermal compound replaced to replace the fans properly without jerry rigging your fans
J M - Yanıt
This tutorial is not complete, some extra steps are required to unplug the fans power connector.
Indeed, it’s necessary to remove the plastic support above the heat sink (where fans are screwed on) to be able to unplug the fans power connector.
First, the fan support should be removed and the connector should be unplugged before unscrewing the fans from the plastic support.
Brendan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 44
Son 30 gün: 205
Her zaman: 2,121
