Ana içeriğe geç
Radiator/thermostat valve repair
Neye ihtiyacın var
    1. Radiator/thermostat valve repair, Radiator-/thermostat-valve: adım 1, 1 resimden 1.
      • Fully open the thermostat/valve
      FixBot'a Sor
      Yorum Ekle
    2. Radiator/thermostat valve repair: adım 2, 1 resimden 1.
      • Undo the screw on the fastening clamp. In this case an older thermostat is shown. Newer models probably have a twist and screw cap and you may not need tools at all.
      • Remove the thermostat head.
      FixBot'a Sor
      Yorum Ekle
    3. Radiator/thermostat valve repair: adım 3, 1 resimden 1.
      • Put some multipurpose oil onto the little transmission pin.
      FixBot'a Sor
      Yorum Ekle
    4. Radiator/thermostat valve repair: adım 4, 1 resimden 1.
      • By tapping the pin CAREFULLY with a hammer, you can make it move again.
      FixBot'a Sor
      Yorum Ekle
    5. Radiator/thermostat valve repair: adım 5, 2 resimden 1. Radiator/thermostat valve repair: adım 5, 2 resimden 2.
      • Add some additional lubrication to the pin before screwing the thermostat back on.
      • By pushing the pin in and let it come back out several times using the hammer again, the oil should evenly distribute on the pin, so that in future it is very unlikely, that it is seizing up soon again.
      • That's it! Put the valve/thermostat back on and fix it in place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow the steps in reverse order.
6 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Martin Herterich
311 İtibar
1 Kılavuz yazıldı
Ekip
iFixit EU Team iFixit EU Team üyesi
Staff
37 Üyeler
3.069 adet Kılavuz yazıldı
1Rehber Yorum
Can this old type valve still be available
Kevin - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 98
Son 30 gün: 328
Her zaman: 15,981
