Ana içeriğe geç
Raidmax Alpha Case Graphics Card Replacement
Neye ihtiyacın var
  1. Raidmax Alpha Case Graphics Card Replacement, Graphics Card: adım 1, 3 resimden 1. Raidmax Alpha Case Graphics Card Replacement, Graphics Card: adım 1, 3 resimden 2. Raidmax Alpha Case Graphics Card Replacement, Graphics Card: adım 1, 3 resimden 3.
    • Turn off the computer and the power supply to the computer.
    FixBot'a Sor
    Yorum Ekle
  2. Raidmax Alpha Case Graphics Card Replacement: adım 2, 2 resimden 1. Raidmax Alpha Case Graphics Card Replacement: adım 2, 2 resimden 2.
    • Recycle the power in the computer by pressing the power button on and off again. This removes any remaining current to the computer.
    FixBot'a Sor
    Yorum Ekle
  3. Raidmax Alpha Case Graphics Card Replacement: adım 3, 3 resimden 1. Raidmax Alpha Case Graphics Card Replacement: adım 3, 3 resimden 2. Raidmax Alpha Case Graphics Card Replacement: adım 3, 3 resimden 3.
    • Access the glass side panel by turning the back of the case to the left when looking at it from the front.
    FixBot'a Sor
    Yorum Ekle
  4. Raidmax Alpha Case Graphics Card Replacement: adım 4, 3 resimden 1. Raidmax Alpha Case Graphics Card Replacement: adım 4, 3 resimden 2. Raidmax Alpha Case Graphics Card Replacement: adım 4, 3 resimden 3.
    • Remove the two screws on the glass side panel. These are thumb screws so they can simply be removed by twisting them to the left.
    FixBot'a Sor
    Yorum Ekle
  5. Raidmax Alpha Case Graphics Card Replacement: adım 5, 3 resimden 1. Raidmax Alpha Case Graphics Card Replacement: adım 5, 3 resimden 2. Raidmax Alpha Case Graphics Card Replacement: adım 5, 3 resimden 3.
    • Carefully slide the glass panel to the left and then pull it off to remove it.
    FixBot'a Sor
    Yorum Ekle
  6. Raidmax Alpha Case Graphics Card Replacement: adım 6, 3 resimden 1. Raidmax Alpha Case Graphics Card Replacement: adım 6, 3 resimden 2. Raidmax Alpha Case Graphics Card Replacement: adım 6, 3 resimden 3.
    • Tilt the case backward and lay it on its backside. This is done so the card will not pull down when being removed.
    FixBot'a Sor
    Yorum Ekle
  7. Raidmax Alpha Case Graphics Card Replacement: adım 7, 3 resimden 1. Raidmax Alpha Case Graphics Card Replacement: adım 7, 3 resimden 2. Raidmax Alpha Case Graphics Card Replacement: adım 7, 3 resimden 3.
    • Undo the power connection to the card. Push the clip on the connector and pull the cable up.
    FixBot'a Sor
    Yorum Ekle
  8. Raidmax Alpha Case Graphics Card Replacement: adım 8, 3 resimden 1. Raidmax Alpha Case Graphics Card Replacement: adım 8, 3 resimden 2. Raidmax Alpha Case Graphics Card Replacement: adım 8, 3 resimden 3.
    • Remove three 6.3 mm screws to the card located on the left side of the case using a Phillips #2 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Raidmax Alpha Case Graphics Card Replacement: adım 9, 2 resimden 1. Raidmax Alpha Case Graphics Card Replacement: adım 9, 2 resimden 2.
    • Push down the clip to the motherboard circled in red.
    FixBot'a Sor
    Yorum Ekle
  10. Raidmax Alpha Case Graphics Card Replacement: adım 10, 3 resimden 1. Raidmax Alpha Case Graphics Card Replacement: adım 10, 3 resimden 2. Raidmax Alpha Case Graphics Card Replacement: adım 10, 3 resimden 3.
    • Carefully grip the old graphics card with two hands and lift it out of the case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 25
Son 30 gün: 72
Her zaman: 4,818
