Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Before removing the crank arms, the pedals must be removed first. Follow this guide to the crank arms to replace the chain guard. To reassemble the crank arms and chain guard, follow steps in reverse order.
  1. First take an 8 in adjustable crescent wrench and fit it around the base of the pedal.
    • First take an 8 in adjustable crescent wrench and fit it around the base of the pedal.
  2. To unscrew the chain side pedal twist the the wrench counter  clockwise. To unscrew the pedal that is on the side away from the chain, twist the wrench clockwise.
    • To unscrew the chain side pedal twist the the wrench counter clockwise.
    • To unscrew the pedal that is on the side away from the chain, twist the wrench clockwise.
  3. Continue turning the wrench until the pedal detaches from the crank arm.
    • Continue turning the wrench until the pedal detaches from the crank arm.
  4. Use a flathead screwdriver to remove the cap over the screw. Do this for both sides.
    • Use a flathead screwdriver to remove the cap over the screw.
    • Do this for both sides.
  5. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  6. To unscrew crank-arms,  position socket wrench onto screw. Twist the socket wrench clockwise until the screw has been removed.
    • To unscrew crank-arms, position socket wrench onto screw.
    • Twist the socket wrench clockwise until the screw has been removed.
  7. Insert the crank arm puller into the hole that the screw was occupying. Use a crescent wrench to tighten the crank arm puller by twisting clockwise until the puller cannot be tightened further. Do not over tighten the crank arm puller. Once it begins to become hard to tighten, stop.
    • Insert the crank arm puller into the hole that the screw was occupying.
    • Use a crescent wrench to tighten the crank arm puller by twisting clockwise until the puller cannot be tightened further.
    • Do not over tighten the crank arm puller. Once it begins to become hard to tighten, stop.
  8. Turn the crank arm puller clockwise until the crankarm pops off. There will be some resistance when taking the crank arm off. Repeat steps 2-4 on the other side of the bike to remove the other crank arm.
    • Turn the crank arm puller clockwise until the crankarm pops off.
    • There will be some resistance when taking the crank arm off.
    • Repeat steps 2-4 on the other side of the bike to remove the other crank arm.
  9. Flip the crank arm, that has the chain-guard on it, over so that the chainring shows. Locate the four screws on the back of the chain ring.
    • Flip the crank arm, that has the chain-guard on it, over so that the chainring shows.
    • Locate the four screws on the back of the chain ring.
  10. Use a Phillips head screwdriver to remove the four screws on the back of the chain ring. Use a Phillips head screwdriver to remove the four screws on the back of the chain ring. Use a Phillips head screwdriver to remove the four screws on the back of the chain ring.
    • Use a Phillips head screwdriver to remove the four screws on the back of the chain ring.
  11. Flip chain guard back over so that the chain guard faces you.
    • Flip chain guard back over so that the chain guard faces you.
  12. Grasp the crankarm in one hand and the chain guard in the other. Gently, pull out and up on the chain guard until the guard pops off.
    • Grasp the crankarm in one hand and the chain guard in the other.
    • Gently, pull out and up on the chain guard until the guard pops off.
Sonuç
If you are replacing the chain guard, use the new chain guard when reassembling the device.
Carl Lind
49 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 7-49, Forte Fall 2012 Cal Poly, Team 7-49, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G49
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 33
Her zaman: 2,955
