Ana içeriğe geç
Raleigh M20 Handlebars Replacement
Neye ihtiyacın var
  1. Raleigh M20 Handlebars Replacement, Handlebars: adım 1, 2 resimden 1. Raleigh M20 Handlebars Replacement, Handlebars: adım 1, 2 resimden 2.
    • Strip all the accessories from your old handlebars. (reflectors, mirrors, etc...)
    • Using a 3/8" Allen wrench, loosen the nuts that hold the brake controls and gear shifters.
  2. Raleigh M20 Handlebars Replacement: adım 2, 3 resimden 1. Raleigh M20 Handlebars Replacement: adım 2, 3 resimden 2. Raleigh M20 Handlebars Replacement: adım 2, 3 resimden 3.
    • Place an Allen wrench (size doesn't matter) under the bike grip.
    • Twist the grip back and forth while pulling on the Allen wrench to remove the grip.
  3. Raleigh M20 Handlebars Replacement: adım 3, 2 resimden 1. Raleigh M20 Handlebars Replacement: adım 3, 2 resimden 2.
    • Slide off the gear shifters.
    • Slide off the brake controls.
  4. Raleigh M20 Handlebars Replacement: adım 4, 3 resimden 1. Raleigh M20 Handlebars Replacement: adım 4, 3 resimden 2. Raleigh M20 Handlebars Replacement: adım 4, 3 resimden 3.
    • Loosen the central nut on the faceplate that connects the bars to the steering column. If the bars are secured by a faceplate with a detachable top, loosen the nuts on the faceplate and remove.
    • Lift the handlebars from the bike frame.
    • Move the bars until they're in the correct position for your stance. Tighten the faceplate nuts with a 3/8" Allen wrench to firmly secure the handlebars in place.
    • Sit on the bike and make final adjustments to the positioning of the brakes and gears.
Sonuç
To reinstall the handlebars, complete these steps in reverse order. If there is a problem with the alignment, return to the handlebar repair guide and repeat step 4.
Jon Ribera
72 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-49, Forte Fall 2012 Cal Poly, Team 7-49, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G49
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 2,094
