Ana içeriğe geç
Raleigh M20 Seat Cushion Replacement
Neye ihtiyacın var
  1. Raleigh M20 Seat Cushion Replacement, Seat Cushion: adım 1, 3 resimden 1. Raleigh M20 Seat Cushion Replacement, Seat Cushion: adım 1, 3 resimden 2. Raleigh M20 Seat Cushion Replacement, Seat Cushion: adım 1, 3 resimden 3.
    • Loosen the seat clamp by pulling the black lever away from the frame. Once this is done, simply rotate the lever counter-clockwise to loosen the seat.
    • Stand on the right side of the bike while loosening the lever and make sure the bike isn't upside-down. This will prevent the seat from falling off during this process.
  2. Raleigh M20 Seat Cushion Replacement: adım 2, 2 resimden 1. Raleigh M20 Seat Cushion Replacement: adım 2, 2 resimden 2.
    • Now that the seat is loosened, slowly pull up on the seat cushion until it is fully out of the frame. Next, place the seat on the ground.
  3. Raleigh M20 Seat Cushion Replacement: adım 3, 2 resimden 1. Raleigh M20 Seat Cushion Replacement: adım 3, 2 resimden 2.
    • Use an Allen wrench to unscrew the bolt that is holding the post to the seat cushion.
  4. Raleigh M20 Seat Cushion Replacement: adım 4, 3 resimden 1. Raleigh M20 Seat Cushion Replacement: adım 4, 3 resimden 2. Raleigh M20 Seat Cushion Replacement: adım 4, 3 resimden 3.
    • Now that the bolt is loosened, carefully pull the seat cushion from the post. Next remove the two riders as shown in the second image.
Sonuç
Now you are ready to reassemble the seat with your new cushion. Just follow these same steps in the reverse order. Thanks for taking the time to use this guide!
Bir başkası bu kılavuzu tamamladı.
Dante Bozzini
35 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-49, Forte Fall 2012 Cal Poly, Team 7-49, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G49
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 1,963
