Ana içeriğe geç
Razer Basilisk V3 Skates Replacement
Neye ihtiyacın var
  1. Razer Basilisk V3 Skates Replacement, Skates: adım 1, 1 resimden 1.
    • Locate each of the skates.
  2. Razer Basilisk V3 Skates Replacement: adım 2, 3 resimden 1. Razer Basilisk V3 Skates Replacement: adım 2, 3 resimden 2. Razer Basilisk V3 Skates Replacement: adım 2, 3 resimden 3.
    • Heat the skate using a heat gun or hair dryer.
    • Using the pointy end of the spudger pry away a corner of the skate.
    • If the adhesive does not pull away easily, heat the skate more.
    • Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
    • Repeat these steps for each of the skates.
Sonuç
To replace the skates heat the new skates until the adhesive is sticky. Then apply to the appropriate space.
Sarah
219 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Santin Spring 2024 UMass Dartmouth, Team 1-2, Santin Spring 2024 üyesi
UMASSD-SANTIN-S24S1G2
3 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 73
Her zaman: 396
