Ana içeriğe geç
Razer BlackWidow Chroma Lights Replacement
Neye ihtiyacın var
  1. Razer BlackWidow Chroma Lights Replacement, Lights: adım 1, 1 resimden 1.
    • Gently pull off the four rubber tabs located on the corners of the keyboard with your fingers.
  2. Razer BlackWidow Chroma Lights Replacement: adım 2, 1 resimden 1.
    • Using a metal spudger, gently remove the plastic tabs that are covering the two screws.
  3. Razer BlackWidow Chroma Lights Replacement: adım 3, 1 resimden 1.
    • There are six 10mm screws indicated by the red markups . Remove the screws using the Phillips #0 Screwdriver.
  4. Razer BlackWidow Chroma Lights Replacement: adım 4, 2 resimden 1. Razer BlackWidow Chroma Lights Replacement: adım 4, 2 resimden 2.
    • Using a metal spudger, begin prying off the faceplate of the keyboard. There are small tabs along the edge of the keyboard and the faceplate that must be released. There are four tabs along the front of the keyboard and two along each side.
  5. Razer BlackWidow Chroma Lights Replacement: adım 5, 1 resimden 1.
    • Using a plastic opening tool, lift the plastic covering away from the LED light.
  6. Razer BlackWidow Chroma Lights Replacement: adım 6, 2 resimden 1. Razer BlackWidow Chroma Lights Replacement: adım 6, 2 resimden 2.
    • Using the Phillips #0 Screwdriver, remove the ten 10mm screws that are indicated by the red markers.
    • Click the link below to watch a video that will guide you through the rest of the steps on how to replace LEDs in the keyboard. This step does require soldering . How to Replace Back-light LEDs
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Brooke Stevenson
182 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team 2-6, Rose Winter 2017 UW Tacoma, Team 2-6, Rose Winter 2017 üyesi
UWT-ROSE-W17S2G6
3 Üyeler
3 adet Kılavuz yazıldı
2 Yorum
Anyone know what type of LEDs are need for the replacement?
Huayu Nie - Yanıt
High brightness led’s, 3mm.
Carlos Eduardo Pereira Reis -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 58
Her zaman: 17,535
