Giriş
In this replacement guide we will go over how to disassemble the Razer BlackWidow Chroma. After disassembling the keyboard there will be a link on how to solder and replace the lights.
Neye ihtiyacın var
Gently pull off the four rubber tabs located on the corners of the keyboard with your fingers.
Click the link below to watch a video that will guide you through the rest of the steps on how to replace LEDs in the keyboard. This step does require soldering . How to Replace Back-light LEDs
3 farklı kişi bu kılavuzu tamamladı.
2 Yorum
High brightness led’s, 3mm.
