Ana içeriğe geç
Razer BlackWidow Chroma Wire Harness Replacement
Neye ihtiyacın var
  1. Razer BlackWidow Chroma Wire Harness Replacement, Rubber Feet: adım 1, 2 resimden 1. Razer BlackWidow Chroma Wire Harness Replacement, Rubber Feet: adım 1, 2 resimden 2.
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer BlackWidow Chroma Wire Harness Replacement, Front Panel: adım 2, 2 resimden 1. Razer BlackWidow Chroma Wire Harness Replacement, Front Panel: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer BlackWidow Chroma Wire Harness Replacement, Wire Harness: adım 3, 1 resimden 1.
    • Using a Philips #1 screwdriver, remove all ten screws found on the edges of the keyboard.
    • Two of the screws are found on either side of the main cable.
  4. Razer BlackWidow Chroma Wire Harness Replacement: adım 4, 2 resimden 1. Razer BlackWidow Chroma Wire Harness Replacement: adım 4, 2 resimden 2.
    • Remove the wire harness.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 1,671
