Giriş
This guide shows the disassembly of the volume knob of a Razer BlackWidow Elite keyboard. The volume knob of this particular model is notorious for being iffy. Many hacks on the internet have been proposed to fix the problem, but they're usually ineffective. Hopefully, this guide helps with diagnosing the problem with it.
Neye ihtiyacın var
Turn the keyboard over so the backside is exposed.
Remove the top rubber feet to reveal the hidden screws.
After unscrewing the bracket, the button of the volume knob should come right off.
On the main component of the volume knob, the circuit board should be rotatable. Rotate the circuit board so that the cutout aligns with the hidden screw.
There should be 2 (3mm) screws. Use a Phillips #000 screwdriver to remove them.
2 farklı kişi bu kılavuzu tamamladı.
