Ana içeriğe geç
Razer Blackwidow Chroma Key Switch Replacement
Neye ihtiyacın var
  1. Razer Blackwidow Chroma Key Switch Replacement, Rubber Feet: adım 1, 2 resimden 1. Razer Blackwidow Chroma Key Switch Replacement, Rubber Feet: adım 1, 2 resimden 2.
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Chroma Key Switch Replacement, Front Panel: adım 2, 2 resimden 1. Razer Blackwidow Chroma Key Switch Replacement, Front Panel: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer Blackwidow Chroma Key Switch Replacement, Back Panel: adım 3, 2 resimden 1. Razer Blackwidow Chroma Key Switch Replacement, Back Panel: adım 3, 2 resimden 2.
    • Use a Philips #1 Screwdriver to remove the four screws located below the keys.
    • Lift the main circuit board and flip it over, placing it on its top.
    • Be cautious of the wire connected to the USB Port Board.
  4. Razer Blackwidow Chroma Key Switch Replacement, Key Switch: adım 4, 3 resimden 1. Razer Blackwidow Chroma Key Switch Replacement, Key Switch: adım 4, 3 resimden 2. Razer Blackwidow Chroma Key Switch Replacement, Key Switch: adım 4, 3 resimden 3.
    • De-solder the anchor of each key that you desire to replace with a soldering iron.
    • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
    • Remove the key switch once the de-soldering is complete.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
3 Yorum
hello where to buy the switches for this keyboard?
ninja636 - Yanıt
I've seen Razer Green Switches (the ones for the Blackwidow) with RGB lighting available for sale on eBay.
I hope that helps!
Matt Von Grimm -
Hi Annika, I have razer black widow chroma overwatch edition, Is gateron optical switch compatible with it?
Jaydeep Parmar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 73
Son 30 gün: 409
Her zaman: 20,363
