Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Turn the keyboard over so that it is lying flat on its face. Use the iFixit opening tool to pry the rubber feet off the keyboard.
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard. Then use the IFixIt opening tool to pry off the front panel.
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Then use the IFixIt opening tool to pry off the front panel.
    • Place the keyboard over so the keys are facing up.
    • Lift both ends of the keyboard up removing the front panel.
  3. Use a Philips #1 Screwdriver to remove the four screws located below the keys. Lift the main circuit board and flip it over, placing it on its top. Be cautious of the wire connected to the USB Port Board.
    • Use a Philips #1 Screwdriver to remove the four screws located below the keys.
    • Lift the main circuit board and flip it over, placing it on its top.
    • Be cautious of the wire connected to the USB Port Board.
  4. Use a Philips #1 Screwdriver to remove the two screws located on the bottom of the USB Port Board. Lift the USB Port Board and place it to the side.
    • Use a Philips #1 Screwdriver to remove the two screws located on the bottom of the USB Port Board.
    • Lift the USB Port Board and place it to the side.
Sonuç
Advika Chesetti
85 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 24
Her zaman: 371
