Ana içeriğe geç
Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement
Neye ihtiyacın var
  1. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Rubber Feet: adım 1, 2 resimden 1. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Rubber Feet: adım 1, 2 resimden 2.
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Front Panel: adım 2, 2 resimden 1. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Front Panel: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Back Panel: adım 3, 2 resimden 1. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Back Panel: adım 3, 2 resimden 2.
    • Use a Philips #1 Screwdriver to remove the four screws located below the keys.
    • Lift the main circuit board and flip it over, placing it on its top.
    • Be cautious of the wire connected to the USB Port Board.
  4. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, USB Port: adım 4, 2 resimden 1. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, USB Port: adım 4, 2 resimden 2.
    • Pull on the wire connector until it disconnects from the USB port board.
    • You may use either your hands or a pair of tweezers to separate the white connection clip.
Sonuç
Bir Yorum
Where can I get another USB board? And it's possible to build one from scratch? I was thinking in upgrading to a USB C port
Eduwardo Horibe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 17
Her zaman: 1,921
