Ana içeriğe geç
Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement
Neye ihtiyacın var
  1. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: adım 1, 3 resimden 1. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: adım 1, 3 resimden 2. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: adım 1, 3 resimden 3.
    • Remove the four plastic covers and rubber feet from all four corners of the keyboard.
    • Remove the four screws.
    • Carefully pry around the bottom end of the keyboard and work your way around keyboard to un-clip the face.
  2. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: adım 2, 2 resimden 1. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: adım 2, 2 resimden 2.
    • Turn the keyboard face up.
    • Remove the four screws which attach the keys.
    • Note the orientation of the white plastic cover relative to the LED at the bottom of the board.
  3. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: adım 3, 1 resimden 1.
    • Locate the USB at the top of the device.
    • Remove the two screws attaching the USB.
  4. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: adım 4, 2 resimden 1. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: adım 4, 2 resimden 2.
    • Unplug the cable connecting to the USB board.
    • Plug the new USB board into the slot.
    • Replace the screws in the USB board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
4 Yorum
hi, where do i get the new board from? thanks!
Doge The Best - Yanıt
You can easily find it on Ebay
Here's a link, i had the same issue
https://www.ebay.com/itm/272275162673htt...
iixroyal owlroyal -
I need one too
kevin oliveira - Yanıt
Hey, you can easily Google the details on the USB board bottom left
I had the same issue
iixroyal owlroyal - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 35
Her zaman: 5,014
