Giriş
This is a guide for replacing the keys of a Razer Blackwidow Ultimate 2013. It goes into detail about the steps you need to follow to replace the keys for this keyboard model. Some of the reasons to change the keys include: Cracked or faded keys, scratched keys, or keys popping out. Be sure to unplug the keyboard from the computer. A metal spudger will be needed for larger keys.
Neye ihtiyacın var
The regular size keys only require your fingers to remove them, so gently pull them off the keyboard.
3 farklı kişi bu kılavuzu tamamladı.
2 Yorum
You described how to remove a key cover. You did not describe how to remove a key switch and whether or not replacement switches may be purchased.
