Ana içeriğe geç
Razer Blade 15" (2020) Back Cover Replacement
Neye ihtiyacın var
  1. Razer Blade 15" (2020) Back Cover Replacement, Unfasten the back cover: adım 1, 1 resimden 1.
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  2. Razer Blade 15" (2020) Back Cover Replacement, Loosen the back cover: adım 2, 3 resimden 1. Razer Blade 15" (2020) Back Cover Replacement, Loosen the back cover: adım 2, 3 resimden 2. Razer Blade 15" (2020) Back Cover Replacement, Loosen the back cover: adım 2, 3 resimden 3.
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  3. Razer Blade 15" (2020) Back Cover Replacement, Remove the back cover: adım 3, 3 resimden 1. Razer Blade 15" (2020) Back Cover Replacement, Remove the back cover: adım 3, 3 resimden 2. Razer Blade 15" (2020) Back Cover Replacement, Remove the back cover: adım 3, 3 resimden 3.
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
Sonuç
Clay Eickemeyer
82.642 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.545 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 535
