Ana içeriğe geç
Razer Blade RZ09-0102 Fan Replacement
Neye ihtiyacın var
  1. Razer Blade RZ09-0102 Fan Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Before you begin, be sure to turn off your laptop.
    • Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
    • Remove the back cover.
  2. Razer Blade RZ09-0102 Fan Replacement, Fan: adım 2, 1 resimden 1.
    • Remove the three black rubber pads that cover the screws holding the fan.
  3. Razer Blade RZ09-0102 Fan Replacement: adım 3, 1 resimden 1.
    • Use the Phillips #0 screwdriver to remove the three 1/4 inch screws.
  4. Razer Blade RZ09-0102 Fan Replacement: adım 4, 1 resimden 1.
    • Disconnect the wire that goes from the fan into the white connector, but leave the wire attached to the fan.
  5. Razer Blade RZ09-0102 Fan Replacement: adım 5, 2 resimden 1. Razer Blade RZ09-0102 Fan Replacement: adım 5, 2 resimden 2.
    • Lift the fan out with your hands.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 6,604
