Ana içeriğe geç
Razer Blade RZ09-0130 2015 Display Replacement
Neye ihtiyacın var
  1. Razer Blade RZ09-0130 2015 Display Replacement, Back Panel: adım 1, 2 resimden 1. Razer Blade RZ09-0130 2015 Display Replacement, Back Panel: adım 1, 2 resimden 2.
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Display Replacement: adım 2, 2 resimden 1. Razer Blade RZ09-0130 2015 Display Replacement: adım 2, 2 resimden 2.
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Display Replacement, Display: adım 3, 1 resimden 1.
    • Remove the two 5mm Phillips #00 screws.
  4. Razer Blade RZ09-0130 2015 Display Replacement: adım 4, 1 resimden 1.
    • Remove the plastic panel.
  5. Razer Blade RZ09-0130 2015 Display Replacement: adım 5, 1 resimden 1.
    • Remove one 3mm Phillips #00 screw from the metal plate.
  6. Razer Blade RZ09-0130 2015 Display Replacement: adım 6, 1 resimden 1.
    • Repeat the previous three steps on the opposing side.
  7. Razer Blade RZ09-0130 2015 Display Replacement: adım 7, 1 resimden 1.
    • Gently open the device with your hands and separate the display from the keyboard.
    • The device will make a popping or cracking sound when the two pieces separate. This is normal.
Sonuç
Ben Haering
121 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G1, White Winter 2020 Cal Poly, Team S18-G1, White Winter 2020 üyesi
CPSU-WHITE-W20S18G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 748
