Ana içeriğe geç
Razer Blade RZ09-0130 2015 Fan Replacement
Neye ihtiyacın var
  1. Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: adım 1, 2 resimden 1. Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: adım 1, 2 resimden 2.
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Fan Replacement: adım 2, 2 resimden 1. Razer Blade RZ09-0130 2015 Fan Replacement: adım 2, 2 resimden 2.
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Fan Replacement, Fan: adım 3, 2 resimden 1. Razer Blade RZ09-0130 2015 Fan Replacement, Fan: adım 3, 2 resimden 2.
    • Remove the three screw caps by pulling them upward with your fingers.
  4. Razer Blade RZ09-0130 2015 Fan Replacement: adım 4, 1 resimden 1.
    • Remove the three 3mm Phillips #0 screws.
  5. Razer Blade RZ09-0130 2015 Fan Replacement: adım 5, 2 resimden 1. Razer Blade RZ09-0130 2015 Fan Replacement: adım 5, 2 resimden 2.
    • Peel back the two adhesive strips from the fan until they are removed.
  6. Razer Blade RZ09-0130 2015 Fan Replacement: adım 6, 3 resimden 1. Razer Blade RZ09-0130 2015 Fan Replacement: adım 6, 3 resimden 2. Razer Blade RZ09-0130 2015 Fan Replacement: adım 6, 3 resimden 3.
    • Remove the connector by pulling it away from the motherboard with your fingers.
  7. Razer Blade RZ09-0130 2015 Fan Replacement: adım 7, 1 resimden 1.
    • Holding the rounded edge of the fan, slowly lift upwards until it is removed.
  8. Razer Blade RZ09-0130 2015 Fan Replacement: adım 8, 1 resimden 1.
    • Repeat the preceding steps to remove the second fan.
Sonuç
Tyler Clayton
183 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G1, White Winter 2020 Cal Poly, Team S18-G1, White Winter 2020 üyesi
CPSU-WHITE-W20S18G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 16
Her zaman: 610
