Ana içeriğe geç
Razer Blade RZ09-0130 2015 Speaker Replacement
Neye ihtiyacın var
  1. Razer Blade RZ09-0130 2015 Speaker Replacement, Back Panel: adım 1, 2 resimden 1. Razer Blade RZ09-0130 2015 Speaker Replacement, Back Panel: adım 1, 2 resimden 2.
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Speaker Replacement: adım 2, 2 resimden 1. Razer Blade RZ09-0130 2015 Speaker Replacement: adım 2, 2 resimden 2.
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the two 3mm screws from the right speaker.
  4. Razer Blade RZ09-0130 2015 Speaker Replacement: adım 4, 2 resimden 1. Razer Blade RZ09-0130 2015 Speaker Replacement: adım 4, 2 resimden 2.
    • Using your fingers, gently pull on the wire connecting the speaker to the motherboard until it disconnects.
  5. Razer Blade RZ09-0130 2015 Speaker Replacement: adım 5, 1 resimden 1.
    • Pick up and remove the speaker.
  6. Razer Blade RZ09-0130 2015 Speaker Replacement: adım 6, 1 resimden 1.
    • Repeat the preceding steps to remove the second speaker.
Sonuç
Carson Kellerman
495 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G1, White Winter 2020 Cal Poly, Team S18-G1, White Winter 2020 üyesi
CPSU-WHITE-W20S18G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 15
Her zaman: 344
