Ana içeriğe geç
Razer Blade RZ09-0130 2015 Trackpad Button Replacement
Neye ihtiyacın var
  1. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: adım 1, 2 resimden 1. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: adım 1, 2 resimden 2.
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: adım 2, 2 resimden 1. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: adım 2, 2 resimden 2.
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: adım 3, 3 resimden 1. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: adım 3, 3 resimden 2. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: adım 3, 3 resimden 3.
    • Detach the two connectors from the motherboard by gently pulling them directly out of their ports with your fingers.
  4. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: adım 4, 2 resimden 1. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws holding the trackpad's circuit board to the chassis.
  5. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: adım 5, 1 resimden 1.
    • Remove the trackpad circuit board by holding one end and gently lifting it upwards.
Sonuç
Carson Kellerman
495 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G1, White Winter 2020 Cal Poly, Team S18-G1, White Winter 2020 üyesi
CPSU-WHITE-W20S18G1
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Looking for that small ribbon cable, very hard to find, any clues?
serpentexotics - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 2,153
