Ana içeriğe geç
Razer Blade Stealth 2016 Fan Replacement
Neye ihtiyacın var
  1. Razer Blade Stealth 2016  Fan Replacement, Battery: adım 1, 3 resimden 1. Razer Blade Stealth 2016  Fan Replacement, Battery: adım 1, 3 resimden 2. Razer Blade Stealth 2016  Fan Replacement, Battery: adım 1, 3 resimden 3.
    • Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016  Fan Replacement: adım 2, 2 resimden 1. Razer Blade Stealth 2016  Fan Replacement: adım 2, 2 resimden 2.
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016  Fan Replacement: adım 3, 1 resimden 1.
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016  Fan Replacement, Fans: adım 4, 2 resimden 1. Razer Blade Stealth 2016  Fan Replacement, Fans: adım 4, 2 resimden 2.
    • Remove the three 3.38 mm screws from the left fan (this fan should be black).
  5. Razer Blade Stealth 2016  Fan Replacement: adım 5, 1 resimden 1.
    • Carefully lift and remove the left fan.
  6. Razer Blade Stealth 2016  Fan Replacement: adım 6, 3 resimden 1. Razer Blade Stealth 2016  Fan Replacement: adım 6, 3 resimden 2. Razer Blade Stealth 2016  Fan Replacement: adım 6, 3 resimden 3.
    • Repeat steps five and six to remove the silver, right fan.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Katie Murphy
139 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Leahy Fall 2019 USF Tampa, Team S1-G4, Leahy Fall 2019 üyesi
USFT-LEAHY-F19S1G4
4 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
I’m trying to figure out how to attach the ribbons to the motherboard.
Richard Howard - Yanıt
Are the two fans the same?
Mohd Azli Mahmud - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 1,709
