Ana içeriğe geç
Razer Blade Stealth 2016 Hard Drive Replacement
Neye ihtiyacın var
  1. Razer Blade Stealth 2016 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Turn the laptop upside down!
  2. Razer Blade Stealth 2016 Hard Drive Replacement: adım 2, 1 resimden 1.
    • There are 10 screws in total, they can be found at the red circles shown in the picture!
    • NOTE : you need to use a T5 screwdriver!
  3. Razer Blade Stealth 2016 Hard Drive Replacement: adım 3, 1 resimden 1.
    • The hard drive is located under the fan on the left side as shown in the picture!
  4. Razer Blade Stealth 2016 Hard Drive Replacement: adım 4, 1 resimden 1.
    • The hard drive is located under the fan on the left side.
    • Slowly peel back the silver piece and black tape beneath it to reveal the hard drive.
  5. Razer Blade Stealth 2016 Hard Drive Replacement: adım 5, 2 resimden 1. Razer Blade Stealth 2016 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Using a Phillips screwdriver, remove the 2.5 mm screw on the left side of the hard drive.
    • After you unscrew the hard drive, it will pop out by itself
    • The Phillips screw driver is included in the kit that was provided on step 2!
  6. Razer Blade Stealth 2016 Hard Drive Replacement: adım 6, 2 resimden 1. Razer Blade Stealth 2016 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Carefully slide the hard drive out from its slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lindsay Grant
403 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Leahy Fall 2019 USF Tampa, Team S1-G4, Leahy Fall 2019 üyesi
USFT-LEAHY-F19S1G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 47
Her zaman: 3,048
