Ana içeriğe geç
Razer Blade Stealth 2016 Keyboard Replacement
Neye ihtiyacın var
  1. Razer Blade Stealth 2016 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Razer Blade Stealth 2016 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Razer Blade Stealth 2016 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Keyboard Replacement: adım 2, 2 resimden 1. Razer Blade Stealth 2016 Keyboard Replacement: adım 2, 2 resimden 2.
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Keyboard Replacement: adım 3, 1 resimden 1.
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Keyboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Remove the red and black cables that are attached to the motherboard.
  5. Razer Blade Stealth 2016 Keyboard Replacement: adım 5, 1 resimden 1.
    • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
    • Remove the heatsink.
  6. Razer Blade Stealth 2016 Keyboard Replacement: adım 6, 1 resimden 1.
    • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
    • Remove the cooling fans.
  7. Razer Blade Stealth 2016 Keyboard Replacement: adım 7, 3 resimden 1. Razer Blade Stealth 2016 Keyboard Replacement: adım 7, 3 resimden 2. Razer Blade Stealth 2016 Keyboard Replacement: adım 7, 3 resimden 3.
    • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
  8. Razer Blade Stealth 2016 Keyboard Replacement: adım 8, 1 resimden 1.
    • Remove the motherboard.
  9. Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: adım 9, 3 resimden 1. Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: adım 9, 3 resimden 2. Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: adım 9, 3 resimden 3.
    • Flip all white tabs up to unlock three ZIF connectors using the opening tool.
    • Flip all black tabs up to unlock the three ZIF connectors using the opening tool.
    • This is how the tabs look in the flipped up position.
  10. Razer Blade Stealth 2016 Keyboard Replacement: adım 10, 3 resimden 1. Razer Blade Stealth 2016 Keyboard Replacement: adım 10, 3 resimden 2. Razer Blade Stealth 2016 Keyboard Replacement: adım 10, 3 resimden 3.
    • Pull the cables out gently.
  11. Razer Blade Stealth 2016 Keyboard Replacement: adım 11, 3 resimden 1. Razer Blade Stealth 2016 Keyboard Replacement: adım 11, 3 resimden 2. Razer Blade Stealth 2016 Keyboard Replacement: adım 11, 3 resimden 3.
    • Remove fifty-five 3.4 mm keyboard screws with the T5 Torx screwdriver.
    • 5 screw locations are highlighted but locate all 55 screws and remove them.
  12. Razer Blade Stealth 2016 Keyboard Replacement: adım 12, 3 resimden 1. Razer Blade Stealth 2016 Keyboard Replacement: adım 12, 3 resimden 2. Razer Blade Stealth 2016 Keyboard Replacement: adım 12, 3 resimden 3.
    • Remove the keyboard from the laptop.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 52
Her zaman: 875
