Ana içeriğe geç
Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement
Neye ihtiyacın var
  1. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: adım 1, 3 resimden 1. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: adım 1, 3 resimden 2. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: adım 1, 3 resimden 3.
    • Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: adım 2, 2 resimden 1. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: adım 2, 2 resimden 2.
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: adım 3, 1 resimden 1.
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: adım 4, 3 resimden 1. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: adım 4, 3 resimden 2. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: adım 4, 3 resimden 3.
    • Carefully remove the auxiliary and main wire from the Killer 1535 wireless card.
  5. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: adım 5, 3 resimden 1. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: adım 5, 3 resimden 2. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the two 2.61 mm screw holding the card in place.
  6. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: adım 6, 2 resimden 1. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: adım 6, 2 resimden 2.
    • Carefully remove the card.
Sonuç
Kaitlyn Murray
239 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Leahy Fall 2019 USF Tampa, Team S1-G4, Leahy Fall 2019 üyesi
USFT-LEAHY-F19S1G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 953
