Giriş
This guide outlines how to replace the fans in the Razer Blade Stealth 2017. The fans keep the laptop cool and prevent the other components from overheating. A fan replacement may be necessary if the fans are damaged, not turning on, or not functioning optimally. If the fans are making abnormally loud sounds when running, they may need to be replaced. Some tools are required for this replacement.
Neye ihtiyacın var
Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
What is the part number for the black fan? I'm trying to buy a replacement but I can't find any :(
