Ana içeriğe geç
Razer Blade Stealth 2017 HDMI and USB-A Port Replacement
Neye ihtiyacın var
  1. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement, Battery: adım 1, 2 resimden 1. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement, Battery: adım 1, 2 resimden 2.
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: adım 2, 1 resimden 1.
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: adım 3, 2 resimden 1. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: adım 3, 2 resimden 2.
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: adım 5, 2 resimden 1. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: adım 5, 2 resimden 2.
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement, HDMI and USB-A Port: adım 6, 2 resimden 1. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement, HDMI and USB-A Port: adım 6, 2 resimden 2.
    • Use a plastic spudger to lift up the press-fit interconnect cable and expose the USB-A and HDMI port module.
  7. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: adım 7, 2 resimden 1. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to squeeze the fan's white header.
    • Disconnect the fan connector by sliding it out toward the rear of the chassis.
  8. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: adım 8, 2 resimden 1. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: adım 8, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two, 3mm screws from the USB-A and HDMI port module.
  9. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: adım 9, 1 resimden 1.
    • Use a plastic spudger to remove the USB-A and HDMI port module from the case.
    • Do not damage the interconnect cable during removal!
Sonuç
Helene Willits
762 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S11-G3, Regan Fall 2019 Cal Poly, Team S11-G3, Regan Fall 2019 üyesi
CPSU-REGAN-F19S11G3
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 1,102
