Ana içeriğe geç
Razer DeathAdder Chroma Optical Sensor Replacement
Neye ihtiyacın var
  1. Razer DeathAdder Chroma Optical Sensor Replacement, Outer Casing: adım 1, 1 resimden 1.
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Turn the mouse over so the bottom is facing up.
  2. Razer DeathAdder Chroma Optical Sensor Replacement: adım 2, 2 resimden 1. Razer DeathAdder Chroma Optical Sensor Replacement: adım 2, 2 resimden 2.
    • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
  3. Razer DeathAdder Chroma Optical Sensor Replacement: adım 3, 2 resimden 1. Razer DeathAdder Chroma Optical Sensor Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
  4. Razer DeathAdder Chroma Optical Sensor Replacement: adım 4, 1 resimden 1.
    • Use your fingers to identify the location of the screw under the bottom label.
  5. Razer DeathAdder Chroma Optical Sensor Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Clear the label away from around the screw for easier removal.
  6. Razer DeathAdder Chroma Optical Sensor Replacement: adım 6, 3 resimden 1. Razer DeathAdder Chroma Optical Sensor Replacement: adım 6, 3 resimden 2. Razer DeathAdder Chroma Optical Sensor Replacement: adım 6, 3 resimden 3.
    • Turn the mouse over so the bottom is facing down.
    • Separate the top casing from the bottom base by pulling the top casing upwards.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
  7. Razer DeathAdder Chroma Optical Sensor Replacement: adım 7, 2 resimden 1. Razer DeathAdder Chroma Optical Sensor Replacement: adım 7, 2 resimden 2.
    • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
    • Pulling too hard could damage the wire connections.
  8. Razer DeathAdder Chroma Optical Sensor Replacement, Motherboard: adım 8, 2 resimden 1. Razer DeathAdder Chroma Optical Sensor Replacement, Motherboard: adım 8, 2 resimden 2.
    • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
  9. Razer DeathAdder Chroma Optical Sensor Replacement: adım 9, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
  10. Razer DeathAdder Chroma Optical Sensor Replacement: adım 10, 2 resimden 1. Razer DeathAdder Chroma Optical Sensor Replacement: adım 10, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
  11. Razer DeathAdder Chroma Optical Sensor Replacement: adım 11, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
  12. Razer DeathAdder Chroma Optical Sensor Replacement: adım 12, 2 resimden 1. Razer DeathAdder Chroma Optical Sensor Replacement: adım 12, 2 resimden 2.
    • Disconnect the ribbon connector between the motherboard and the optical sensor.
  13. Razer DeathAdder Chroma Optical Sensor Replacement: adım 13, 2 resimden 1. Razer DeathAdder Chroma Optical Sensor Replacement: adım 13, 2 resimden 2.
    • Remove the motherboard by grasping the sides and gently pulling upward.
  14. Razer DeathAdder Chroma Optical Sensor Replacement, Optical Sensor: adım 14, 2 resimden 1. Razer DeathAdder Chroma Optical Sensor Replacement, Optical Sensor: adım 14, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove two 5.5mm screws.
  15. Razer DeathAdder Chroma Optical Sensor Replacement: adım 15, 2 resimden 1. Razer DeathAdder Chroma Optical Sensor Replacement: adım 15, 2 resimden 2.
    • Remove the optical sensor by pulling it forward and up.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Nathan D. Kappler
343 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team S5-G2, Williams Spring 2017 Baylor, Team S5-G2, Williams Spring 2017 üyesi
BU-WILLIAMS-S17S5G2
3 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
Where do I get the part?
youarestaringatme - Yanıt
This is not a sensor, but a sensor backlight. Sensor on the underside of the main board
Guest Night - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 6,162
