Ana içeriğe geç
Razer DeathAdder V3 Pro Encoder Replacement
Neye ihtiyacın var
    1. Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: adım 1, 3 resimden 1. Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: adım 1, 3 resimden 2. Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: adım 1, 3 resimden 3.
      • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
      • Remove the three 7 mm screws using a Torx T6 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Razer DeathAdder V3 Pro Encoder Replacement: adım 2, 2 resimden 1. Razer DeathAdder V3 Pro Encoder Replacement: adım 2, 2 resimden 2.
      • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
      • Insert a spudger into the seam between the top and bottom shells.
      • Gently work around the edges unclipping the internal latches.
      • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
      • Carefully pull the shells apart to unplug the cable in the front.
      FixBot'a Sor
      Yorum Ekle
    3. Razer DeathAdder V3 Pro Encoder Replacement: adım 3, 2 resimden 1. Razer DeathAdder V3 Pro Encoder Replacement: adım 3, 2 resimden 2.
      • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
      FixBot'a Sor
      Yorum Ekle
    1. Razer DeathAdder V3 Pro Encoder Replacement, Encoder: adım 4, 1 resimden 1.
      • Use a T6 Torx screwdriver to remove the 5mm screws securing the circuit board.
      • Unplug the battery from its connection on the right side.
      • Be careful not to break the two clips that hold the PCB at the front of the mouse.
      FixBot'a Sor
      Yorum Ekle
    2. Razer DeathAdder V3 Pro Encoder Replacement: adım 5, 1 resimden 1.
      • At the front of the PCB next to the encoder, remove the switch held in place by clips by gently pulling it free.
      FixBot'a Sor
      Yorum Ekle
    3. Razer DeathAdder V3 Pro Encoder Replacement: adım 6, 2 resimden 1. Razer DeathAdder V3 Pro Encoder Replacement: adım 6, 2 resimden 2.
      • Wear eye protection.
      • Take care not to damage the PCB or any other components.
      • Use a pair of flush cutters to cut the legs of the encoder.
      • Desolder the legs of the 15 mm encoder on the underside of the PCB.
      • Remove the encoder.
      • Always solder in a well ventilated area.
      • Use a solder sucker to remove any excess solder.
      FixBot'a Sor
      Yorum Ekle
    4. Razer DeathAdder V3 Pro Encoder Replacement: adım 7, 1 resimden 1.
      • Press the new 15 mm encoder into place
      • If the encoder does not fit properly, clean the old solder more thoroughly.
      • Solder the new 15 mm encoder into place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Nicholas
453 İtibar
4 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 2-5, Johansen Fall 2025 Texas Tech, Team 2-5, Johansen Fall 2025 üyesi
TTU-JOHANSEN-F25S2G5
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 50
Son 30 gün: 262
Her zaman: 1,425
