Ana içeriğe geç
Razer DeathAdder V3 Pro USB-C Port Replacement
Neye ihtiyacın var
    1. Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: adım 1, 3 resimden 1. Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: adım 1, 3 resimden 2. Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: adım 1, 3 resimden 3.
      • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
      • Remove the three 7 mm screws using a Torx T6 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Razer DeathAdder V3 Pro USB-C Port Replacement: adım 2, 2 resimden 1. Razer DeathAdder V3 Pro USB-C Port Replacement: adım 2, 2 resimden 2.
      • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
      • Insert a spudger into the seam between the top and bottom shells.
      • Gently work around the edges unclipping the internal latches.
      • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
      • Carefully pull the shells apart to unplug the cable in the front.
      FixBot'a Sor
      Yorum Ekle
    3. Razer DeathAdder V3 Pro USB-C Port Replacement: adım 3, 2 resimden 1. Razer DeathAdder V3 Pro USB-C Port Replacement: adım 3, 2 resimden 2.
      • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
      FixBot'a Sor
      Yorum Ekle
    1. Razer DeathAdder V3 Pro USB-C Port Replacement, USB-C Port: adım 4, 1 resimden 1.
      • Use a T6 Torx screwdriver to remove the 5mm screws from the circuit board.
      • Unplug the battery from its connection on the right.
      • Be careful not to break the two clips that hold the PCB at the front of the mouse.
      • Remove the circuit board from the mouse.
      FixBot'a Sor
      Yorum Ekle
    2. Razer DeathAdder V3 Pro USB-C Port Replacement: adım 5, 1 resimden 1.
      • Always solder in a well ventilated area.
      • Apply solder to the four anchor points on the back corners and side of the USB-C port.
      • Once the solder has melted, use tweezers to remove the USB-C port.
      • Use a solder sucker to clean the area.
      FixBot'a Sor
      Yorum Ekle
    3. Razer DeathAdder V3 Pro USB-C Port Replacement: adım 6, 1 resimden 1.
      • Apply flux, then apply solder to one anchor point to help line up the new USB-C port.
      • Once the USB-C port is aligned, apply flux to the other three anchor points and solder them.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Nicholas
453 İtibar
4 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 2-5, Johansen Fall 2025 Texas Tech, Team 2-5, Johansen Fall 2025 üyesi
TTU-JOHANSEN-F25S2G5
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 48
Her zaman: 333
