Ana içeriğe geç
Razer Deathadder Elite Scroll Wheel Replacement
Neye ihtiyacın var
  1. Razer Deathadder Elite Scroll Wheel Replacement, Scroll Wheel: adım 1, 2 resimden 1. Razer Deathadder Elite Scroll Wheel Replacement, Scroll Wheel: adım 1, 2 resimden 2.
    • Pry the skate off the two upper screws.
    • Remove the two upper screws using a Phillips #00 screwdriver.
    • Poke a hole with your screwdriver into the product sticker on the bottom of the mouse.
    • Remove the bottom screw using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Razer Deathadder Elite Scroll Wheel Replacement: adım 2, 2 resimden 1. Razer Deathadder Elite Scroll Wheel Replacement: adım 2, 2 resimden 2.
    • Lift up the upper shell of the mouse.
    • Use caution; the shell if still connected to the base.
    • Detach the two wired connectors from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  3. Razer Deathadder Elite Scroll Wheel Replacement: adım 3, 3 resimden 1. Razer Deathadder Elite Scroll Wheel Replacement: adım 3, 3 resimden 2. Razer Deathadder Elite Scroll Wheel Replacement: adım 3, 3 resimden 3.
    • Unscrew the scroll wheel LED.
    • Carefully remove the scroll wheel.
    FixBot'a Sor
    Yorum Ekle
  4. Razer Deathadder Elite Scroll Wheel Replacement: adım 4, 1 resimden 1.
    • Insert the replacement wheel into the mouse.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Hamilton Liu
256 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
Hi! What size and manufacturer is the encoder in this mouse?
m2l2kopower - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 34
Son 30 gün: 168
Her zaman: 7,683
