Ana içeriğe geç
Razer Huntsman TE Keycaps Replacement
  1. Razer Huntsman TE Keycaps Replacement, Keycaps: adım 1, 2 resimden 1. Razer Huntsman TE Keycaps Replacement, Keycaps: adım 1, 2 resimden 2.
    • Identify the correct type of key to replace.
    • Keys such as "Shift" and "Enter" have multiple slots, and each slot has a different shape, so be sure to pick the correct one.
  2. Razer Huntsman TE Keycaps Replacement: adım 2, 2 resimden 1. Razer Huntsman TE Keycaps Replacement: adım 2, 2 resimden 2.
    • Insert the keycap puller so that the teeth at the end of the puller sit beneath the keycap.
    • Apply enough upwards force for the keycap to pop out.
  3. Razer Huntsman TE Keycaps Replacement: adım 3, 2 resimden 1. Razer Huntsman TE Keycaps Replacement: adım 3, 2 resimden 2.
    • Apply 91% isopropyl alcohol to microfiber cloth.
    • Wipe around the key.
    • Make sure that there is no residual stickiness on the key.
  4. Razer Huntsman TE Keycaps Replacement: adım 4, 2 resimden 1. Razer Huntsman TE Keycaps Replacement: adım 4, 2 resimden 2.
    • Position the replacement keycap above the keyslot.
    • Using your finger, apply downwards force to the keycap until you hear it snap into place.
Sonuç
Use a diagnostic tool such as an online keyboard tester to test the key.
Lucas de Castro
109 İtibar
1 Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 52
Her zaman: 1,501
