Ana içeriğe geç
Razer Huntsman Tournament Edition Chassis Replacement
Neye ihtiyacın var
  1. Razer Huntsman Tournament Edition Chassis Replacement, Keycaps: adım 1, 1 resimden 1.
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Chassis Replacement: adım 2, 2 resimden 1. Razer Huntsman Tournament Edition Chassis Replacement: adım 2, 2 resimden 2.
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Chassis Replacement: adım 3, 3 resimden 1. Razer Huntsman Tournament Edition Chassis Replacement: adım 3, 3 resimden 2. Razer Huntsman Tournament Edition Chassis Replacement: adım 3, 3 resimden 3.
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
  4. Razer Huntsman Tournament Edition Chassis Replacement, Chassis: adım 4, 1 resimden 1.
    • Remove all of the keycaps with a keycap puller.
  5. Razer Huntsman Tournament Edition Chassis Replacement: adım 5, 2 resimden 1. Razer Huntsman Tournament Edition Chassis Replacement: adım 5, 2 resimden 2.
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
  6. Razer Huntsman Tournament Edition Chassis Replacement: adım 6, 1 resimden 1.
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
  7. Razer Huntsman Tournament Edition Chassis Replacement: adım 7, 1 resimden 1.
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
  8. Razer Huntsman Tournament Edition Chassis Replacement: adım 8, 1 resimden 1.
    • Disconnect the internal cable.
Sonuç
Ben Altman
229 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S4G3
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 438
