Ana içeriğe geç
Razer Huntsman Tournament Edition Port Replacement
Neye ihtiyacın var
  1. Razer Huntsman Tournament Edition Port Replacement, Keycaps: adım 1, 1 resimden 1.
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Port Replacement: adım 2, 2 resimden 1. Razer Huntsman Tournament Edition Port Replacement: adım 2, 2 resimden 2.
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Port Replacement: adım 3, 3 resimden 1. Razer Huntsman Tournament Edition Port Replacement: adım 3, 3 resimden 2. Razer Huntsman Tournament Edition Port Replacement: adım 3, 3 resimden 3.
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
  4. Razer Huntsman Tournament Edition Port Replacement, Chassis: adım 4, 1 resimden 1.
    • Remove all of the keycaps with a keycap puller.
  5. Razer Huntsman Tournament Edition Port Replacement: adım 5, 3 resimden 1. Razer Huntsman Tournament Edition Port Replacement: adım 5, 3 resimden 2. Razer Huntsman Tournament Edition Port Replacement: adım 5, 3 resimden 3.
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
    • Screw placement and quantity may vary per unit.
    • If you have removed all screws and the front panel cannot be removed, there may be an additional screw near the USB port, below the sticker. (See third photo)
  6. Razer Huntsman Tournament Edition Port Replacement: adım 6, 1 resimden 1.
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
  7. Razer Huntsman Tournament Edition Port Replacement: adım 7, 1 resimden 1.
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
  8. Razer Huntsman Tournament Edition Port Replacement: adım 8, 1 resimden 1.
    • Disconnect the internal cable.
  9. Razer Huntsman Tournament Edition Port Replacement, Port: adım 9, 2 resimden 1. Razer Huntsman Tournament Edition Port Replacement, Port: adım 9, 2 resimden 2.
    • Unscrew the board with the port.
    • It should be located on the upper left, held in by two 6.5mm Phillips #0 screws.
    • Move the cable out of the way for the second screw
  10. Razer Huntsman Tournament Edition Port Replacement: adım 10, 1 resimden 1.
    • Detach the internal cable from the USB board.
    • Do this carefully.
  11. Razer Huntsman Tournament Edition Port Replacement: adım 11, 1 resimden 1.
    • Remove the USB board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joseph O'Dowd
401 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S4G3
5 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
how do i get a new port and where
Guardian Suit - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 590
