Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Computer Hardware cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Razer Hyperflux Teardown, Removing the grip: adım 1, 1 resimden 1.
    • Turn the mousepad over and peel off the grip with the white plastic layer.
    • The white plastic layer is glued to the device only on it's edges so if you're using the ifixit head pad you only need to put it on the edges.
    • Be sure to peel the grip + the white plastic layer. Removing just the grip and then the plastic layer will result in a very tedious process of trying to align the grip properly.
  2. Razer Hyperflux Teardown, Removing the PCB shield: adım 2, 1 resimden 1.
    • Unscrew the 3 screws with a phillips head screwdriver
  3. Razer Hyperflux Teardown, Removing the PCB: adım 3, 3 resimden 1. Razer Hyperflux Teardown, Removing the PCB: adım 3, 3 resimden 2. Razer Hyperflux Teardown, Removing the PCB: adım 3, 3 resimden 3.
    • Desolder the copper leads (red circle) and open the gate of the connector (blue circle)
    • You can now safely take out the pcb
    • For reassembly simply follow the steps in reverse
SgtBlade
109 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 50
Her zaman: 1,704
