Ana içeriğe geç
Razer Kraken Ultimate Volume Wheel Replacement
Neye ihtiyacın var
  1. Razer Kraken Ultimate Volume Wheel Replacement, Ear Pads: adım 1, 3 resimden 1. Razer Kraken Ultimate Volume Wheel Replacement, Ear Pads: adım 1, 3 resimden 2. Razer Kraken Ultimate Volume Wheel Replacement, Ear Pads: adım 1, 3 resimden 3.
    • Grab the ear piece from one of the sides and lightly pull it outwards.
    • Ideally, do not pull the ear piece directly away from the speaker; it may damage the piece.
  2. Razer Kraken Ultimate Volume Wheel Replacement: adım 2, 2 resimden 1. Razer Kraken Ultimate Volume Wheel Replacement: adım 2, 2 resimden 2.
    • Once you have taken off one side, you can then remove the whole piece by slowly prying the pad away from the headphones.
  3. Razer Kraken Ultimate Volume Wheel Replacement: adım 3, 2 resimden 1. Razer Kraken Ultimate Volume Wheel Replacement: adım 3, 2 resimden 2.
    • Repeat steps on the other side.
  4. Razer Kraken Ultimate Volume Wheel Replacement, Speaker: adım 4, 3 resimden 1. Razer Kraken Ultimate Volume Wheel Replacement, Speaker: adım 4, 3 resimden 2. Razer Kraken Ultimate Volume Wheel Replacement, Speaker: adım 4, 3 resimden 3.
    • Remove the four 10 mm Phillips #00 screws securing the right speaker.
    • Be sure the device is unplugged before attempting to remove any of the screws.
  5. Razer Kraken Ultimate Volume Wheel Replacement: adım 5, 2 resimden 1. Razer Kraken Ultimate Volume Wheel Replacement: adım 5, 2 resimden 2.
    • Remove the 10 mm Phillips #00 screws securing the left speaker.
    • Note that one of the screws is hidden behind the product information sticker. Use your screw driver to punch a hole in the sticker.
  6. Razer Kraken Ultimate Volume Wheel Replacement: adım 6, 2 resimden 1. Razer Kraken Ultimate Volume Wheel Replacement: adım 6, 2 resimden 2.
    • To fully detach the speakers cut the wires as close as possible to the connection point, leaving plenty of room to solder the new speaker on.
  7. Razer Kraken Ultimate Volume Wheel Replacement, Microphone: adım 7, 3 resimden 1. Razer Kraken Ultimate Volume Wheel Replacement, Microphone: adım 7, 3 resimden 2. Razer Kraken Ultimate Volume Wheel Replacement, Microphone: adım 7, 3 resimden 3.
    • Remove the two 10 mm Phillips #00 screws securing the microphone.
  8. Razer Kraken Ultimate Volume Wheel Replacement: adım 8, 1 resimden 1.
    • Gently pry the bottom connection away from the casing with the iFixit opening tool.
  9. Razer Kraken Ultimate Volume Wheel Replacement: adım 9, 2 resimden 1. Razer Kraken Ultimate Volume Wheel Replacement: adım 9, 2 resimden 2.
    • Pull the microphone down and out of the casing.
  10. Razer Kraken Ultimate Volume Wheel Replacement: adım 10, 1 resimden 1.
    • Open up the casing the microphone retracks into.
    • Cut the cable as close to the microphone as possible, leaving behind enough to solder the new microphone to.
    • The casing the microphone if removed correctly in the previous step is easily opened by hand
  11. Razer Kraken Ultimate Volume Wheel Replacement, Volume Wheel: adım 11, 2 resimden 1. Razer Kraken Ultimate Volume Wheel Replacement, Volume Wheel: adım 11, 2 resimden 2.
    • The volume wheel is located on the daughterboard.
    • Remove the single 6.0 mm Philips #00 screw.
  12. Razer Kraken Ultimate Volume Wheel Replacement: adım 12, 1 resimden 1.
    • Gently pull the board out of the housing.
    • Be careful not to tug on the connected ribbon cable.
  13. Razer Kraken Ultimate Volume Wheel Replacement: adım 13, 2 resimden 1. Razer Kraken Ultimate Volume Wheel Replacement: adım 13, 2 resimden 2.
    • The wheel can be easily removed after removing the daughterboard.
Sonuç
Alex Broggi
342 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Petersen Fall 2022 UMass Dartmouth, Team 1-4, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S1G4
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 36
Her zaman: 864
