Ana içeriğe geç
Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair
Neye ihtiyacın var
  1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair, Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: adım 1, 3 resimden 1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair, Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: adım 1, 3 resimden 2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair, Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: adım 1, 3 resimden 3.
    • To get to the maelstrom wiring you must first pull off the plastic cover.
    • To do this roll the maelstrom over so the rubber cover on the back is facing up. The rubber pad simply peels off exposing the metal backplate.
    • Then remove the four 8.5mm screws on the back plate of the maelstrom.
  2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: adım 2, 2 resimden 1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: adım 2, 2 resimden 2.
    • Once the four screws are removed, the top cover can be lifted off.
    • There is a ribbon wire connecting the volume wheel to the circuit board. This is not permanently attached, and can be plugged back in if it gets pulled out.
    • Remove the three 2mm screws from the circuit board to separate it from the back plate.
  3. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: adım 3, 2 resimden 1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: adım 3, 2 resimden 2.
    • The circuit board is now completely separate from the housing and the wires can now be inspected.
    • Peel back the tape on the wires to inspect any damage to the wires if there is any.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Kyle Schober
640 İtibar
5 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 üyesi
MTU-LAUER-S14S5G8
3 Üyeler
13 adet Kılavuz yazıldı
4 Yorum
Well for the last step the wires I peeled the wires by burning them on a gas ranger. Worked Perfectly.
Edwin Lopez - Yanıt
can you provide the connection map for the cables that go prom remote root to headphones?
johnny1992black - Yanıt
comeon you wanna tell me you took picture of the cables from one side and the other one not this is a joke right?
muchas gracias por este articulo, es el 2020 y me a servido mucho para arreglar mis audifonos
diego.riquelme.cortes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 23
Her zaman: 5,958
