Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the left ear cushion by rotating the cushion counter clockwise as far as it goes, then pull straight up to pull the cushion off the device.
    • Remove the left ear cushion by rotating the cushion counter clockwise as far as it goes, then pull straight up to pull the cushion off the device.
  2. Remove the six 6 mm screws around the speaker housing. Although it is only possible to reassemble this piece one way, you can save yourself some trouble by making a mark that lines up the speaker housing with the ear cup. Although it is only possible to reassemble this piece one way, you can save yourself some trouble by making a mark that lines up the speaker housing with the ear cup.
    • Remove the six 6 mm screws around the speaker housing.
    • Although it is only possible to reassemble this piece one way, you can save yourself some trouble by making a mark that lines up the speaker housing with the ear cup.
  3. Remove the three 6 mm screws on the inside of the ear cup.
    • Remove the three 6 mm screws on the inside of the ear cup.
  4. There are two wires going into the boom. One powers the LED lights and the other goes to the microphone. Each wire has two smaller ones in them. Cut both wires, strip the shielding, solder the new wires together, and wrap them in electrical tape or use heat shrink. Be sure to insulate the wires from each other.
    • There are two wires going into the boom. One powers the LED lights and the other goes to the microphone. Each wire has two smaller ones in them.
    • Cut both wires, strip the shielding, solder the new wires together, and wrap them in electrical tape or use heat shrink. Be sure to insulate the wires from each other.
    • The two sets of wires are different colors so you do not need to worry about figuring out which wire powers the LEDs and which goes to the microphone.
Sonuç
Nicholas Samokyszyn
338 İtibar
3 adet Kılavuz yazıldı
Takım
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 üyesi
MTU-LAUER-S14S5G8
3 Üyeler
9 adet Kılavuz yazıldı
3 Comments
Ok, so where does one get a replacement boom mic?
stolensoulz79 - Yanıt
My classmate saw a pair of headphones on a
website today. He thought it was nice looking and good price. He asked me my
opinion. What do you think? Here is the link:
kobe - Yanıt
opinion. What do you think? Here is the link: http://menghu.ebcoo.net/product/original...
kobe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 6
Her zaman: 1,984
