Ana içeriğe geç
Razer Naga Expert MMO Side Button Connection Strip Replacement
Neye ihtiyacın var
  1. Razer Naga Expert MMO Side Button Connection Strip Replacement, Top Plastic Shell: adım 1, 1 resimden 1.
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Razer Naga Expert MMO Side Button Connection Strip Replacement: adım 2, 1 resimden 1.
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga Expert MMO Side Button Connection Strip Replacement: adım 3, 1 resimden 1.
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Razer Naga Expert MMO Side Button Connection Strip Replacement: adım 4, 1 resimden 1.
    • Lightly pull the two plastic sides of the mouse to remove them.
  5. Razer Naga Expert MMO Side Button Connection Strip Replacement, Side Button Connection Strip: adım 5, 1 resimden 1.
    • Flip back the black plastic that holds the white connection strip in place on the side panel and the main panel.
  6. Razer Naga Expert MMO Side Button Connection Strip Replacement: adım 6, 1 resimden 1.
    • Gently remove the white connection strip at each end.
  7. Razer Naga Expert MMO Side Button Connection Strip Replacement: adım 7, 1 resimden 1.
    • Insert the blue striped ends into the white connection port on the mainframe as well as the frame with the buttons.
Sonuç
Bir Yorum
What is the code for the connection strip and how many pins does it have?
Thank you for the guide.
Tsuki Yomi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 2,332
