Ana içeriğe geç
Razer Naga Expert MMO Top Plastic Shell Replacement
Neye ihtiyacın var
  1. Razer Naga Expert MMO Top Plastic Shell Replacement, Top Plastic Shell: adım 1, 1 resimden 1.
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Razer Naga Expert MMO Top Plastic Shell Replacement: adım 2, 1 resimden 1.
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga Expert MMO Top Plastic Shell Replacement: adım 3, 1 resimden 1.
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Razer Naga Expert MMO Top Plastic Shell Replacement: adım 4, 1 resimden 1.
    • Lightly pull the two plastic sides of the mouse to remove them.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Gianni Conti
461 İtibar
2 adet Kılavuz yazıldı
2 Yorum
do you know where i can get a new top body section? i have a molten that stopped left clicking on every click, i opened it up and the plastic pretty much was worn away
pipsqueak642 - Yanıt
i’m after the rubber adhesive for the side of this mouse if any one knows where to buy it from cheers.
mayo22 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 1,842
