Ana içeriğe geç
Razer Naga Trinity LED Light Ribbon Cable Replacement
Neye ihtiyacın var
  1. Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: adım 1, 2 resimden 1. Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: adım 1, 2 resimden 2.
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity LED Light Ribbon Cable Replacement: adım 2, 2 resimden 1. Razer Naga Trinity LED Light Ribbon Cable Replacement: adım 2, 2 resimden 2.
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity LED Light Ribbon Cable Replacement: adım 3, 1 resimden 1.
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity LED Light Ribbon Cable Replacement: adım 4, 2 resimden 1. Razer Naga Trinity LED Light Ribbon Cable Replacement: adım 4, 2 resimden 2.
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity LED Light Ribbon Cable Replacement: adım 5, 1 resimden 1.
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity LED Light Ribbon Cable Replacement: adım 6, 1 resimden 1.
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity LED Light Ribbon Cable Replacement: adım 7, 2 resimden 1. Razer Naga Trinity LED Light Ribbon Cable Replacement: adım 7, 2 resimden 2.
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: adım 8, 2 resimden 1. Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: adım 8, 2 resimden 2.
    • Using the flat end of a spudger, unlock the ribbon cable holding the clips.
    • Remove the ribbon cable.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 1,572
