Ana içeriğe geç
Razer Ouroboros Battery Replacement
Neye ihtiyacın var
    1. Razer Ouroboros Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Begin by turning the mouse upside down.
      • Use a Phillips #00 to loosen the two captive screws circled in the first image.
      • These screws do NOT come out, they merely loosen.
      • Slide the palm rest toward the back of the mouse. It should slide down its track and come right off.
      FixBot'a Sor
      Yorum Ekle
    2. Razer Ouroboros Battery Replacement: adım 2, 1 resimden 1.
      • This is the bottom of the palm rest.
      • Turn the knob highlighted by the red circle will change the height of the palm rest for maximum comfort.
      FixBot'a Sor
      Yorum Ekle
    3. Razer Ouroboros Battery Replacement: adım 3, 1 resimden 1.
      • The battery compartment is on the back side and is easily viewed once the palm rest is removed. Simply push up gently and the hinged battery door opens from the bottom
      • Place the new battery into circular slot shown in the picture. The battery should be placed in positive side first.
      • You must use rechargeable batteries in this mouse.
      FixBot'a Sor
      Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Brandon Jones
308 İtibar
1 Kılavuz yazıldı
Ekip
8Kılavuz Yorumları
is the battery a standard AA battery size or did they use a different size?
adiforipod - Yanıt Paylaş
Standard AA size mate
Minty Fox - Yanıt Paylaş
… what happens if I don't use a rechargeable battery?
Russell Phillips - Yanıt Paylaş
Its fine… You just need to remember not to put it on the recharging base… and the battery will be basically dead after 24 hour use.
flamespinner1 - Yanıt Paylaş
will any brand battery work or does the stock one have specific specs?
ThrowsMachete - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 54
Her zaman: 21,315
