Giriş
From time to time, the rechargeable battery in this mouse will need to be replaced. This replacement is quite simple and straight forward. Only one piece must be removed in order to access the battery. Please note, this device can only use rechargeable batteries. If there has been damage to the battery, contacting the Razer Tech support is the best option.
For this job, you will need the PH 00 screwdriver. That is the only tool needed here.
Neye ihtiyacın var
Begin by turning the mouse upside down.
Use a Phillips #00 to loosen the two captive screws circled in the first image.
Slide the palm rest toward the back of the mouse. It should slide down its track and come right off.
7 farklı kişi bu kılavuzu tamamladı.
8 Yorum
is the battery a standard AA battery size or did they use a different size?
… what happens if I don't use a rechargeable battery?
Its fine… You just need to remember not to put it on the recharging base… and the battery will be basically dead after 24 hour use.
will any brand battery work or does the stock one have specific specs?
