Ana içeriğe geç
Razer Phone Battery Replacement
Neye ihtiyacın var
  1. Razer Phone Battery Replacement, Display Assembly: adım 1, 3 resimden 1. Razer Phone Battery Replacement, Display Assembly: adım 1, 3 resimden 2. Razer Phone Battery Replacement, Display Assembly: adım 1, 3 resimden 3.
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
    FixBot'a Sor
    Yorum Ekle
  2. Razer Phone Battery Replacement: adım 2, 2 resimden 1. Razer Phone Battery Replacement: adım 2, 2 resimden 2.
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
    FixBot'a Sor
    Yorum Ekle
  3. Razer Phone Battery Replacement: adım 3, 3 resimden 1. Razer Phone Battery Replacement: adım 3, 3 resimden 2. Razer Phone Battery Replacement: adım 3, 3 resimden 3.
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Razer Phone Battery Replacement: adım 4, 2 resimden 1. Razer Phone Battery Replacement: adım 4, 2 resimden 2.
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Razer Phone Battery Replacement: adım 5, 3 resimden 1. Razer Phone Battery Replacement: adım 5, 3 resimden 2. Razer Phone Battery Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
    FixBot'a Sor
    Yorum Ekle
  6. Razer Phone Battery Replacement: adım 6, 2 resimden 1. Razer Phone Battery Replacement: adım 6, 2 resimden 2.
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
    FixBot'a Sor
    Yorum Ekle
  7. Razer Phone Battery Replacement, Battery: adım 7, 3 resimden 1. Razer Phone Battery Replacement, Battery: adım 7, 3 resimden 2. Razer Phone Battery Replacement, Battery: adım 7, 3 resimden 3.
    • Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
    • Remove the connector.
    FixBot'a Sor
    Yorum Ekle
  8. Razer Phone Battery Replacement: adım 8, 2 resimden 1. Razer Phone Battery Replacement: adım 8, 2 resimden 2.
    • Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
    • Grab the bracket with the tweezers and remove it.
    FixBot'a Sor
    Yorum Ekle
  9. Razer Phone Battery Replacement: adım 9, 3 resimden 1. Razer Phone Battery Replacement: adım 9, 3 resimden 2. Razer Phone Battery Replacement: adım 9, 3 resimden 3.
    • Peel off and pull out the elastic tabs at the bottom of the battery.
    FixBot'a Sor
    Yorum Ekle
  10. Razer Phone Battery Replacement: adım 10, 2 resimden 1. Razer Phone Battery Replacement: adım 10, 2 resimden 2.
    • Carefully use the Jimmy to wedge the battery out of the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Bryan
777 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G6, White Winter 2019 Cal Poly, Team S19-G6, White Winter 2019 üyesi
CPSU-WHITE-W19S19G6
4 Üyeler
15 adet Kılavuz yazıldı
5Kılavuz Yorumları
Hey tnx for this but how can i buy replacement battery? my battery lose energy so fast . 100 to 0 in 3 hours or less . :(
Kraytos Barzegar - Yanıt Paylaş
Where can I buy a battery and power button replacement for this phone
Kelly Sales - Yanıt Paylaş
It would be nice to be able to find a batter or one that is compatible. Mine is bloated and while i can get to it easily enough i cannot find a replacement. Even a non oem that would work would be nice.
Ronald Winfrey - Yanıt Paylaş
they dont have replacement batteries the only way is to buy a junk razer phone on ebay or a marketplace see if the battery is still functional and replace it as such ive had to do that and now my battery life is normal again
Wai-Ming Ham - Yanıt Paylaş
If you type rc30-0215 on AliExpress you’ll find the for the Razer Phone 1.
Raposo morto - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 22
Son 30 gün: 118
Her zaman: 19,807
