Ana içeriğe geç
Razer Phone Charging Port Replacement
Neye ihtiyacın var
  1. Razer Phone Charging Port Replacement, Display Assembly: adım 1, 3 resimden 1. Razer Phone Charging Port Replacement, Display Assembly: adım 1, 3 resimden 2. Razer Phone Charging Port Replacement, Display Assembly: adım 1, 3 resimden 3.
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
    FixBot'a Sor
    Yorum Ekle
  2. Razer Phone Charging Port Replacement: adım 2, 2 resimden 1. Razer Phone Charging Port Replacement: adım 2, 2 resimden 2.
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
    FixBot'a Sor
    Yorum Ekle
  3. Razer Phone Charging Port Replacement: adım 3, 3 resimden 1. Razer Phone Charging Port Replacement: adım 3, 3 resimden 2. Razer Phone Charging Port Replacement: adım 3, 3 resimden 3.
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Razer Phone Charging Port Replacement: adım 4, 2 resimden 1. Razer Phone Charging Port Replacement: adım 4, 2 resimden 2.
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Razer Phone Charging Port Replacement: adım 5, 3 resimden 1. Razer Phone Charging Port Replacement: adım 5, 3 resimden 2. Razer Phone Charging Port Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
    FixBot'a Sor
    Yorum Ekle
  6. Razer Phone Charging Port Replacement: adım 6, 2 resimden 1. Razer Phone Charging Port Replacement: adım 6, 2 resimden 2.
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
    FixBot'a Sor
    Yorum Ekle
  7. Razer Phone Charging Port Replacement, Battery: adım 7, 3 resimden 1. Razer Phone Charging Port Replacement, Battery: adım 7, 3 resimden 2. Razer Phone Charging Port Replacement, Battery: adım 7, 3 resimden 3.
    • Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
    • Remove the connector.
    FixBot'a Sor
    Yorum Ekle
  8. Razer Phone Charging Port Replacement: adım 8, 2 resimden 1. Razer Phone Charging Port Replacement: adım 8, 2 resimden 2.
    • Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
    • Grab the bracket with the tweezers and remove it.
    FixBot'a Sor
    Yorum Ekle
  9. Razer Phone Charging Port Replacement: adım 9, 3 resimden 1. Razer Phone Charging Port Replacement: adım 9, 3 resimden 2. Razer Phone Charging Port Replacement: adım 9, 3 resimden 3.
    • Peel off and pull out the elastic tabs at the bottom of the battery.
    FixBot'a Sor
    Yorum Ekle
  10. Razer Phone Charging Port Replacement: adım 10, 2 resimden 1. Razer Phone Charging Port Replacement: adım 10, 2 resimden 2.
    • Carefully use the Jimmy to wedge the battery out of the phone.
    FixBot'a Sor
    Yorum Ekle
  11. Razer Phone Charging Port Replacement, Charging Port: adım 11, 2 resimden 1. Razer Phone Charging Port Replacement, Charging Port: adım 11, 2 resimden 2.
    • Using a Phillips #000 screwdriver, take out the seven 1 mm screws on the bottom panel of the device.
    • There are a few gold brackets under some of the screws. Make sure to remove these and keep them for reassembly.
    FixBot'a Sor
    Yorum Ekle
  12. Razer Phone Charging Port Replacement: adım 12, 2 resimden 1. Razer Phone Charging Port Replacement: adım 12, 2 resimden 2.
    • Grab hold of the blue connector on the upper left side of the phone with the tweezers.
    FixBot'a Sor
    Yorum Ekle
  13. Razer Phone Charging Port Replacement: adım 13, 2 resimden 1. Razer Phone Charging Port Replacement: adım 13, 2 resimden 2.
    • Use the tweezers to grab hold of the connector for the blue wire (bottom of the device), and remove the connector.
    • Use the tweezers to grab hold of the connector for the white wire, and remove the connector.
    FixBot'a Sor
    Yorum Ekle
  14. Razer Phone Charging Port Replacement: adım 14, 1 resimden 1.
    • Using the tweezers, grab the detached charging port and ribbon.
    FixBot'a Sor
    Yorum Ekle
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Bryan
777 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G6, White Winter 2019 Cal Poly, Team S19-G6, White Winter 2019 üyesi
CPSU-WHITE-W19S19G6
4 Üyeler
15 adet Kılavuz yazıldı
10Kılavuz Yorumları
Who i can find one replacement…pls a link
Flims LP - Yanıt Paylaş
Search it on Amazon.c
HolaSoy Guapo - Yanıt Paylaş
hi how much you guys charge for the charging port thanks
johnny rodas - Yanıt Paylaş
Does this tutorial also work for the Razer phone 2?
Derrick - Yanıt Paylaş
Nah, even step one looks different for me.
Edsknife - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 34
Son 30 gün: 118
Her zaman: 27,005
